Page 1 of 1
Installing MacBook Pro 13" Unibody Mid 2009 Left Speaker
- Author: Walter Galan
- Difficulty: Difficult
Restore balanced sound to your laptop by replacing the left speaker.
Sections
- Lower Case 2 steps
- Battery 1 step
- Fan 3 steps
- Logic Board 13 steps
- Microphone 2 steps
- Left Speaker 3 steps
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 3
Battery
For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Edit
Step 4
Fan
Use a spudger to pry the fan connector out of its seat, and straight up off the logic board.
It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Edit
Step 10
In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
Edit
Step 19
Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
Pull the logic board away from the side of the upper case and remove it, minding the DC-in board that may get caught.
Be careful not to rip out the fragile connector plug of the microphone assembly.
Page 1 of 1
