Installing MacBook Pro 13" Unibody Mid 2009 DC-In Board
  • Add Note x
  • x 9
No power to the laptop? Replace the DC-in Board.
Sections
Tools
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
first image
Add Note Edit Step 2  ¶
  • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4 — Fan  ¶
  • Use a spudger to pry the fan connector out of its seat, and straight up off the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
first image
Add Note Edit Step 5  ¶
  • Remove the following three screws securing the fan to the upper case:
    • One 6.5 mm Phillips.
    • One 5.5 mm Phillips.
    • One 4.5 mm Phillips.
first image
Add Note Edit Step 6  ¶
  • Lift the fan out of the upper case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7 — Logic Board  ¶
  • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
  • Pull the display data cable connector straight away from its socket.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7 mm Phillips.
    • One 5 mm Phillips.
  • Lift the display data cable bracket out of the upper case.
first image
Add Note Edit Step 9  ¶
  • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
first image
Add Note Edit Step 10  ¶
  • In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
  • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
  • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 12  ¶
  • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
  • Use your spudger to slide the keyboard ribbon cable out of its socket.
first image
Add Note Edit Step 13  ¶
  • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 14  ¶
  • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
  • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
first image
Add Note Edit Step 15  ¶
  • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
first image
Add Note Edit Step 16  ¶
  • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
first image
Add Note Edit Step 17  ¶
  • Remove the following screws:
    • Five 3.1 mm Phillips.
    • Two 3.9 mm Phillips.
    • Two 7 mm Phillips from the DC-in board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 18  ¶
  • Remove the following tri-wing screws securing the battery to the upper case:
    • One 5.5 mm tri-wing screw.
    • One 13.5 mm tri-wing screw.
  • Lift the battery out of the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 19  ¶
  • Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
  • Pull the logic board away from the side of the upper case and remove it, minding the DC-in board that may get caught.
  • Be careful not to rip out the fragile connector plug of the microphone assembly.
first image
Add Note Edit Step 20 — DC-In Board  ¶
  • Disconnect the DC-In board by pulling its connector away from the socket on the logic board.
For more information, check out the MacBook Pro 13" Unibody Mid 2009 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
