Page 1 of 1
MacBook Core Duo Logic Board Replacement
- Author: iRobot
- Difficulty: Difficult
This motherboard includes all ports on the left side.
Sections
- Battery 2 steps
- Memory Cover 2 steps
- Upper Case 8 steps
- Left I/O Frame 4 steps
- Logic Board 19 steps
- Logic Board Replacement 3 steps
Tools
- View:
- Paginated
- Full width
Edit
Step 11
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
Edit
Step 23
Hold the heat sink with one hand and the fan with your other hand, and lift the heat sink and fan assembly out of the computer. The fan is attached to the heat sink only with a strip of black felt tape, so be sure to remove both parts as a unit
If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Page 1 of 1
