Installing MacBook Core 2 Duo Memory Cover
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 28
This keeps the RAM levers out of the way of the battery and secures the hard drive.
Sections
Tools
Relevant parts
first image
  • Use a coin to rotate the battery-locking screw 90 degrees clockwise.
first image
Add Note Edit Step 2  ¶
  • Lift the battery out of the computer.
first image
Add Note Edit Step 3 — Memory Cover  ¶
  • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
  • The screws are captive to the metal memory cover so you cannot lose them.
first image
Add Note Edit Step 4  ¶
  • Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
For more information, check out the MacBook Core 2 Duo device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
