Installing MacBook Core 2 Duo Bluetooth Board
Add Note Introduction
Replace the Bluetooth board.
Tools used in this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use a coin to rotate the battery-locking screw 90 degrees clockwise.
first image
Add Note Step 2
  • Lift the battery out of the computer.
first image
Add Note Step 3 — Memory Cover
  • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
  • The screws are captive to the metal memory cover.
Add NoteNotes: Step 1
Flag Reply by ServiceDocs Nov 7 @ 11:08 AM
I used this guide plus the Thermal Paste guide to resolve my MacBook RRS (Random Restart Syndrome) issue. My MacBook would randomly restart after the fan kicked into high speed. When I removed the heatsink I discovered an an irregular patch completely free of thermal compound of about 15-20% of the area on one of the processors. I removed and re-applied the thermal paste. I ran a memory test utility overnight that previously caused a restart after a couple of hours, and the probelm seems to be solved. TIme will tell.
Flag Reply by skraggle Nov 13 @ 12:58 PM
This guide was seriously helpful, so thanks for putting this together. I found a thick ribbon of dust/muck whatever between the fan outlet and the exhaust port that was almost as dense as felt. My fan must have been fighting like crazy trying to pass air through that blockage, which explains the high temps and excessive fan noise. Wish I'd done this sooner...
Thanks again!
