Installing MacBook Core 2 Duo Bluetooth Antenna
Add Note Introduction
No signal to Bluetooth? Replace the antenna.
Tools used in this guide
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use a coin to rotate the battery-locking screw 90 degrees clockwise.
first image
Add Note Step 2
  • Lift the battery out of the computer.
first image
Add Note Step 3 — Memory Cover
  • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
  • The screws are captive to the metal memory cover.
Add NoteNotes: Step 1
Flag Reply by ServiceDocs Nov 7 2009 @ 11:08 AM
I used this guide plus the Thermal Paste guide to resolve my MacBook RRS (Random Restart Syndrome) issue. My MacBook would randomly restart after the fan kicked into high speed. When I removed the heatsink I discovered an an irregular patch completely free of thermal compound of about 15-20% of the area on one of the processors. I removed and re-applied the thermal paste. I ran a memory test utility overnight that previously caused a restart after a couple of hours, and the probelm seems to be solved. TIme will tell.
Flag Reply by skraggle Nov 13 2009 @ 12:58 PM
This guide was seriously helpful, so thanks for putting this together. I found a thick ribbon of dust/muck whatever between the fan outlet and the exhaust port that was almost as dense as felt. My fan must have been fighting like crazy trying to pass air through that blockage, which explains the high temps and excessive fan noise. Wish I'd done this sooner...
Thanks again!
Flag Reply by mikeutter Dec 1 2009 @ 10:16 PM
Just R&R'ed the fan in my black MacBook Core 2 Duo tonight. Took me 30 minutes tops and I was taking my time. These instructions are SPOT ON! Great job ifixit.com! Two thumbs up!
Follow the instructions exactly as you see and have a piece of paper taped to the table next to you that you can outline all the screws you took out so you know where they go back in. I expected this to be a LOT harder, but it was one of the simplest repairs I've ever done to ANY computer!
Flag Reply by Mike Woodruff Jan 29 @ 1:17 PM
Piece of cake--or should I say gum. If you don't have a magnetized screwdriver, load up a stick of gum and chomp on it until it's needed then use a bit to retain screw on the driver. And if you should tear the black tape, or if the silver tape won't stick any more, just bubblegum it together. The instructions were clear and correct, which made for a very simple repair.
