Installing MacBook Air Lower Case
Add Note Introduction
Replacing your lower case is easy! It only takes 10 screws.
Tools used in this guide
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Lower Case
  • Remove the following 10 screws securing the lower case to the Air:
    • Six 2.8 mm Phillips screws.
    • Two 3.8 mm Phillips screws.
    • Two 5.4 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Step 2
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
Congratulations!
Share your repair story!
To reassemble your device, follow these instructions in reverse order. For more information, check out the MacBook Air device page.
Did you successfully follow this guide?
Notes
There are no notes
