Installing MacBook Air Models A1237 and A1304 Logic Board Bracket
  • Add Note x
The logic board bracket holds the trackpad control cable connector and the AirPort/Bluetooth connector securely to the logic board.
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the Air:
    • Six 2.8 mm Phillips screws.
    • Two 3.8 mm Phillips screws.
    • Two 5.4 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • Disconnect the battery connector by pulling it straight out of its socket.
first image
Add Note Edit Step 4  ¶
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
first image
Add Note Edit Step 5  ¶
  • Lift the battery out of the Air.
first image
Add Note Edit Step 6 — Logic Board Bracket  ¶
  • Remove the two small Phillips screws securing the logic board bracket to the upper case.
first image
Add Note Edit Step 7  ¶
  • Lift the logic board bracket out of the upper case.
For more information, check out the MacBook Air Models A1237 and A1304 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
