Installing MacBook Air Models A1237 and A1304 Logic Board Bracket
  • Add Note x
The logic board bracket holds the trackpad control cable connector and the AirPort/Bluetooth connector securely to the logic board.
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the Air:
    • Six 2.8 mm Phillips screws.
    • Two 3.8 mm Phillips screws.
    • Two 5.4 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • Disconnect the battery connector by pulling it straight out of its socket.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Related Products
MacBook Air Logic Board Bracket
$9.95 · 31 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
