Installing MacBook Air Heat Sink Replacement
Add Note Introduction
Use this guide to swap out your old heat sink for a new one.
Tools used in this guide
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Lower Case
  • Remove the following 10 screws securing the lower case to the Air:
    • Six 2.8 mm Phillips screws.
    • Two 3.8 mm Phillips screws.
    • Two 5.4 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Step 2
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Step 3 — Battery
  • Disconnect the battery connector by pulling it straight away from its socket.
Notes
There are no notes
