MacBook Air Models A1237 and A1304 Hard Drive Replacement
Replace the hard drive in your MacBook Air Models A1237 and A1304.
  • Add Note x
  • x 62
Replacing your hard drive is easy! Also, you can upgrade to a higher capacity drive for more storage space.
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the Air:
    • Six 2.8 mm Phillips screws.
    • Two 3.8 mm Phillips screws.
    • Two 5.4 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • Disconnect the battery connector by pulling it straight out of its socket.
first image
Add Note Edit Step 4  ¶
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
first image
Add Note Edit Step 5  ¶
  • Lift the battery out of the Air.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6 — Hard Drive  ¶
  • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
  • Pull the audio out ribbon cable off the adhesive securing it to the upper case.
  • Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
first image
Add Note Edit Step 7  ¶
  • Disconnect the audio out cable from its socket on the port hatch ribbon cable.
first image
Add Note Edit Step 8  ¶
  • Use a spudger to pry the hard drive cable connector up off the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • Use the sharp end of a spudger to de-route the microphone cable from the hard drive bracket.
  • Remove the cosmetic screw cover from the adhesive securing it to the hard drive bracket.
first image
Add Note Edit Step 10  ¶
  • Remove the four Phillips screws securing the hard drive assembly to the upper case.
first image
Add Note Edit Step 11  ¶
  • Lift the hard drive assembly out of the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12 — Hard Drive Replacement  ¶
  • Use your thumbs to push the hard drive away from its bracket.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Peel the rubber shock isolator off the perimeter of the hard drive.
first image
Add Note Edit Step 14  ¶
  • If present, remove the small piece of black tape covering the ribbon cable connector.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 15  ¶
  • The two different versions of MacBook Air have different hard drive connectors. Failure to perform the action appropriate to your machine will damage your hard drive! Be very careful when disconnecting the hard drive cable. The ZIF connectors are fragile.
  • If you have the original MacBook Air (A1237), use a spudger or your thumbs to flip up the ribbon cable retaining flap TOWARD the cable (seen in picture 1).
  • If you have the A1304 version of MacBook Air, use a spudger or your thumbs to flip up the ribbon cable retaining flap AWAY from the cable (seen in picture 2).
  • Pull the hard drive cable straight away from its socket.
first image
Add Note Edit Step 16  ¶
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
  • If you need to, transfer the foam from your current hard drive to the new one. The foam does come off by using a spudger and some patience.
  • The two primary options for reading CDs and DVDs on a MacBook Air are to either purchase an external SuperDrive or to use an Apple feature called Remote Disc. Remote Disc allows the optical drive of a nearby Mac to be borrowed for use in mounting discs on the MacBook Air.
For more information, check out the MacBook Air Models A1237 and A1304 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
