Installing Mac mini (PowerPC) RAM
Introduction
| Difficulty: | Moderate |
This machine uses full-size desktop RAM.
Tools used in this guide
Parts relevant to this guide
Paginated Single Page Steps
Step 1
Upper Case
You can skip this step if you bought your putty knife from iFixit. Putty knives purchased from iFixit come with pre-ground edges.
You'll need a putty knife in order to open the case. A 1.5 inch thin putty knife will work well, but you'll want to grind the edge down. Rub the putty knife's short edge back and forth on a sheet of all purpose rough grit sandpaper (100 grit will work fine) until it attains a beveled edge.
Step 2
Place the mini upside down on a cloth and turn it so that the apple leaf faces you.
Insert the putty knife into the seam between silver outer case and the white plastic. If you have trouble, you can insert the putty knife at an angle or grind the knife's edge down further. Push the blade down until you meet firm resistance (roughly 3/8 of an inch).
So, Guys at iFixit, since you are making the beta thing, i have a lot of macs that i can make guides for. if you don't mind user created mac guides, i can make guides for the:
Powermac G4 Cube
Powermac G4 Quicksilver
Powermac G4 MDD
Powermac G3 B&W
iMac G3 (First Gen)
Apple 17" Studio LCD Display
BTW: The required battery is a CR2032
