Installing Mac Mini Mid 2010 RAM
Upgrade the RAM for overall faster performance.
  • Add Note x
  • x 23
Removing the RAM on the mid 2010 Mac Mini is an easy task that requires no tools.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Bottom Cover  ¶
  • Place your thumbs in the depressions cut into the bottom cover.
  • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
first image
Add Note Edit Step 2  ¶
  • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
  • Remove the bottom cover and set it aside.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — RAM  ¶
  • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
For more information, check out the Mac Mini Mid 2010 device page.
Did you successfully follow this guide?
This guide has been completed 23 times.
