Page 1 of 1
Mac mini Model A1283 Hard Drive Replacement
Replace the hard drive in your Mac mini Model A1283.
- Author: Walter Galan
- Difficulty: Moderate
Upgrade your hard drive for more storage space.
Sections
- Top Housing 5 steps
- Internal Frame 7 steps
- Hard Drive 5 steps
- Hard Drive Replacement 2 steps
Tools
- View:
- Paginated
- Full width
Edit Step 1
Top Housing
You can skip this step if you bought your putty knife from iFixit. Putty knives purchased from iFixit come with pre-ground edges.
You'll need a putty knife in order to open the case. A 1.5 inch thin putty knife will work well, but you'll want to grind the edge down. Rub the putty knife's short edge back and forth on a sheet of all purpose rough grit sandpaper (100 grit will work fine) until it attains a beveled edge.
Edit Step 2 ¶
Carefully insert a putty knife into the crevice in between the top cover and bottom housing. Start on the left side first. Push the blade down until you meet firm resistance (roughly 3/8 of an inch).
Gently enlarge the existing crevice by rotating the putty knife downward and away from the mini.
Edit Step 6
Internal Frame
In the next few steps you will be removing the AirPort and Bluetooth antennas (shown in red) from the internal frame. Be very careful, as breaking the brackets will require replacing the internal frame.
We will first remove the AirPort antenna, located in the lower left corner of this picture.
Edit Step 7 ¶
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
Edit Step 13
Hard Drive
In this step, make sure to only disconnect the connector from its socket, and not the entire socket from the interconnect board.
Use the tip of a spudger to gently pry the hard drive thermal sensor connector away from its socket on the interconnect board. Make sure to only detach the connector and not the socket that is soldered to the interconnect board.
NOTE that this connector is tiny, hard to remove and VERY easily damaged. Instead of trying to pry the sensor connector out and risk breaking it, you can jump to Steps 18 and 19 (gently pry the thermal sensor board off of the hard drive and un-tape the wire). Then proceed with Steps 15-17 (unscrewing and removing the hard drive). Once the new hard drive is installed you can attach the thermal sensor to it.
This guide has been completed 78 times.
Page 1 of 1
