Page 1 of 1
Installing Mac mini Model A1283 AirPort/Bluetooth Combo Card
- Author: Walter Galan
- Difficulty: Moderate
Replace your broken AirPort/Bluetoo
Sections
- Top Housing 5 steps
- Internal Frame 7 steps
- AirPort/Bluetooth Combo Card 3 steps
- View:
- Paginated
- Full width
Edit Step 1
Top Housing
You can skip this step if you bought your putty knife from iFixit. Putty knives purchased from iFixit come with pre-ground edges.
You'll need a putty knife in order to open the case. A 1.5 inch thin putty knife will work well, but you'll want to grind the edge down. Rub the putty knife's short edge back and forth on a sheet of all purpose rough grit sandpaper (100 grit will work fine) until it attains a beveled edge.
Edit Step 2 ¶
Carefully insert a putty knife into the crevice in between the top cover and bottom housing. Start on the left side first. Push the blade down until you meet firm resistance (roughly 3/8 of an inch).
Gently enlarge the existing crevice by rotating the putty knife downward and away from the mini.
Edit Step 6
Internal Frame
In the next few steps you will be removing the AirPort and Bluetooth antennas (shown in red) from the internal frame. Be very careful, as breaking the brackets will require replacing the internal frame.
We will first remove the AirPort antenna, located in the lower left corner of this picture.
Edit Step 7 ¶
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
Edit Step 13
Use the flat end of a spudger to pry the three antenna connectors off the AirPort/Bluetooth combo card.
The black antenna cable(bottom left red square) attaches to the AirPort card near the corner of the mini, and the other two Bluetooth antenna cables(top left, right) attaches to the Bluetooth connectors.
Page 1 of 1
