Page 1 of 1
Installing Mac mini Model A1176 AirPort Extreme
- Author: Walter Galan
- Difficulty: Moderate
Replace a broken AirPort card to regain wireless connectivity.
Sections
- Top Housing 5 steps
- Internal Frame 9 steps
- AirPort Antenna 1 step
- AirPort Extreme 2 steps
- View:
- Paginated
- Full width
Edit Step 1
Top Housing
You can skip this step if you bought your putty knife from iFixit. Putty knives purchased from iFixit come with pre-ground edges.
You'll need a putty knife in order to open the case. A 1.5 inch thin putty knife will work well, but you'll want to grind the edge down. Rub the putty knife's short edge back and forth on a sheet of all purpose rough grit sandpaper (100 grit will work fine) until it attains a beveled edge.
Edit Step 2 ¶
Carefully insert a putty knife into the crevice in between the top cover and bottom housing. Start on the left side first. Push the blade down until you meet firm resistance (roughly 3/8 of an inch).
Gently enlarge the existing crevice by prying the handle of the putty knife downward and away from the mini.
It helps to start in the middle, then work along the edge until the bottom housing pops up slightly.
Edit Step 6
Internal Frame
Later in this guide you will remove several recessed Phillips screws. Bit drivers are generally too large to fit in the recesses, so be sure to have a thin shafted Phillips screwdriver on hand.
First remove the AirPort antenna (the larger of the two), located near the power button.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
Edit Step 9 ¶
Rotate the mini so that the SuperDrive slot loading mechanism is facing you.
Use a pair of tweezers to lift the hard drive thermal sensor cable connector up off its socket on the logic board.
Use tweezers to grab the connector (as seen in the picture), not the wires.
The connector is located under the optical drive opening, next to the PRAM battery.
Edit Step 10 ¶
In the next few steps, you will remove the four Phillips screws securing the internal frame to the bottom case. Included in each step is an overview picture showing the general location and a closeup showing the actual screw.
Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
Page 1 of 1
