Installing Mac mini Model A1176 AirPort Extreme
  • Add Note x
  • x 9
Replace a broken AirPort card to regain wireless connectivity.
Sections
first image
Add Note Edit Step 1 — Top Housing  ¶
  • You can skip this step if you bought your putty knife from iFixit. Putty knives purchased from iFixit come with pre-ground edges.
  • You'll need a putty knife in order to open the case. A 1.5 inch thin putty knife will work well, but you'll want to grind the edge down. Rub the putty knife's short edge back and forth on a sheet of all purpose rough grit sandpaper (100 grit will work fine) until it attains a beveled edge.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Carefully insert a putty knife into the crevice in between the top cover and bottom housing. Start on the left side first. Push the blade down until you meet firm resistance (roughly 3/8 of an inch).
  • Gently enlarge the existing crevice by prying the handle of the putty knife downward and away from the mini.
  • It helps to start in the middle, then work along the edge until the bottom housing pops up slightly.
first image
Add Note Edit Step 3  ¶
  • Next insert the putty knife into the crevice on the optical drive slot side of the computer.
  • Pry the putty knife downward while working along the edge of the mini until the bottom housing further separates from the top housing.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
1.5" Thin Putty Knife
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 47 in stock
Anti-Static Wrist Strap
$7.95 · 22 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
PC2-5300 1 GB RAM Chip
$29.95 · 50+ in stock
Arctic Silver Thermal Paste
$8.95 · 50+ in stock
Arctic Silver ArctiClean
$7.95 · 50+ in stock
Notes Add Note Notes are offturn on
