first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • After the installer loads, you will be greeted by a welcome window.
  • Select “Disk Utility” from the Utilities drop down menu.
first image
Add Note Edit Step 5  ¶
  • Select your new hard drive from the left column in Disk Utility.
  • The correct partition type needs to be set for your hard drive.
    • If it's a brand-new hard drive, it may have no partition listed.
    • For an Intel-based machine, you should have "GUID Partition Table" listed.
    • For a Power-PC-based machine, you should have "Apple Partition Map" listed.
  • If the incorrect partition type is listed, proceed to the next step to delete and re-create the partition. If not, proceed to step 8.
  • Warning: Deleting the partition will erase the entire contents of the partition.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • The following two steps are only necessary if your drive's partition is set incorrectly. Erasing a partition will permanently erase all information stored inside.
  • Select the partition on the drive and click the "-" button.
  • When prompted, click the "Remove" button to remove the drive's existing partitions.
  • Once the partitions have been removed, click the "Options..." button.
Next » « Previous
Popular Products
Plastic Opening Tools
$2.95 · 50+ in stock
T10 Torx Screwdriver
$4.95 · 50+ in stock
T5 Torx Screwdriver
$9.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Precision Screw Extractor Set
$19.95 · 50+ in stock
Notes Add Note Notes are offturn on
