Applying Thermal Paste
  • Add Note x
  • x 100
Application of thermal paste is essential to keep the processor cool and happy.
first image
Add Note Edit Step 1 — Thermal Paste  ¶
  • Thermal paste is responsible for conducting heat from the processor to the heat sink. Reassembling a computer without applying thermal paste may cause the processor to overheat, resulting in permanent damage.
  • Before applying a coat of thermal paste, you must first remove any old thermal paste from both the processor surface and the heat sink.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Use the flat end of a spudger to scrape off as much solidified thermal paste from the copper core(s) of the heat sink as possible.
first image
Add Note Edit Step 3  ¶
  • After scraping off the solidified thermal paste, a residue is still present on the copper cores(s).
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Arctic Silver Thermal Paste
$8.95 · 50+ in stock
Popular Products
iPhone 3GS Dock Connector
$49.95 · 32 in stock
Flathead 3/32" or 2.5 mm Screwdriver
$4.95 · 50+ in stock
Metal Spudger Set
$7.95 · 50+ in stock
54 Bit Driver Kit
$24.95 · 50+ in stock
T8 Torx Security Bit Screwdriver
$6.95 · 48 in stock
Notes Add Note Notes are offturn on
