first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Allowing the camera to auto-focus should be fine most of the time. However, in rare circumstances the camera focuses on the background instead of the object you're trying to capture. You can zoom in on the object or move the object away from the background.
  • Many cameras have a close-up or macro mode (often termed the 'flower' setting). Use this mode if your subject is less than 2 feet from the camera.
  • Shoot at the highest resolution possible so you have more flexibility when cropping the shot. We require you upload an image that is at least 800 x 600 pixels.
  • Set your ISO to the lowest possible number (ideally 50-200 ISO). The ISO setting adjusts the camera's sensitivity to light. The higher this setting, the grainier the photo will be.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Finally, on to the guitar string instructions: Unwind the guitar key.
  • It's important to have your hand in the shot in order to convey the action being performed.
  • This can be difficult. It's easy to get your arm in the shot, or have your hand obstruct what you're trying to show.
  • Fill the frame with the part of the subject pertinent to the step you're describing. When in doubt, go closer - but don't use digital zoom.
  • A lone person can often take all the pictures with a fair amount of dexterity and the help of a tripod. Of course, practice makes perfect!
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Remove the bridge pin to free the other side of the string.
  • Sometimes, you need to take the picture slightly differently than you would actually perform the task. Some things are impossible to show the actual action.
  • Removing a bridge pin takes some force wiggling back and forth, which you can't show in a picture. In this case, we removed the pin ahead of time, then put it back for the picture.
  • It's more important to show the 'goal' of the shot than the actual action. In this case, pulling the pin partially out shows the viewer what the complete pin looks like, even though the task is essentially complete by the time the photo is taken.
  • Make sure that your hand (or any other object) does not interfere with the action being performed.
Next » « Previous
Popular Products
PC2-5300 2 GB RAM Chip
$49.95 · 50+ in stock
iPhone 3G and 3GS Mute Button
$4.95 · 12 in stock
$2.95 · 50+ in stock
Magnetizer/Demagnetizer
$4.95 · 48 in stock
Precision Tweezers Set
$7.95 · 28 in stock
Notes Add Note Notes are offturn on
