Repair electronics
    • Seen from below, the handpiece is oval-shaped. Wrap with a cloth, with a pair of pliers, a nutcracker or similar. start where the feet are and put the oval in a circle. At the same time, press the handpiece upside down, ie with the metal shank in front, onto a wooden base, whereby the inner life is expelled.
  1. Repair electronics, Remove handpiece base: step 2, image 1 of 1
    • Remove the underside of the handpiece by carefully lifting the tabs at the two farthest vertexes of the oval with a small screwdriver.
  2. Repair electronics, Remove the rubber pad from the motherboard: step 3, image 1 of 1
    • Remove the rubber pad from the motherboard
  3. Repair electronics, Remove plastic cap from metal shaft: step 4, image 1 of 1
    • Use a puller to remove the plastic cap from the metal shaft to expose the defective rubber boot.
    • Thoroughly clean all housing parts with water and cloth.
    • Thoroughly clean the electronics and mechanics with isopropyl alcohol and a fine brush.
    • Also completely rid the metal shaft of any residue.
  4. Repair electronics, Repair electronics: step 6, image 1 of 1
    • Place the inner workings of the handpiece without housing parts in a container in such a way that the main board points downwards and the battery points upwards.
    • Now fill the container with isopropyl alcohol just enough so that the liquid level reaches the circuit board.
    • Leave to stand for 1-2 hours under supervision, then remove the device from the liquid bath and allow to dry.
  5. Repair electronics, Replace rubber sleeve: step 7, image 1 of 1
    • The defective rubber sleeve on the metal shaft must be replaced. A spare part is available for less than € 4 on eBay under the following designation: "Philips electric toothbrush Waterproof sealing parts for HX6730 HX6930 HX9340».
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
de en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Gerd Conzetti
175 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 29
All Time: 1,026
