Removing Delphi Myfi XM2GO LCD Screen
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
User-Contributed Guide
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
This guide shows how to remove the LCD screen.
  • Author: Aubrey
  • Time required: 10 Minutes
  • Difficulty: Moderate
Image #1
Add Note Edit Step 1 — Removing Delphi MyFi XM2GO Battery Cover  ¶
  • Flip the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
  • The back cover is the access point for the user-removable battery. Removing the back cover also gives the user access to the hard-reset button.
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • Locate the large button on the top back of the device. This button is used to release the latch holding the sliding back cover in place.
  • Press this button at the top while making a firm grip on the battery cover.
  • As the button is pressed, move the cover towards the bottom of the device while applying moderate pressure to the cover.
  • Be careful to not press down too hard on the battery cover as it is made of plastic.
  • The battery removal tab may pop up during the cover removal process.
Image #1
Add Note Edit Step 3  ¶
  • After the cover is removed, the white Lithium Ion battery is visible.
Image #1
Add Note Edit Step 4 — Removing Delphi MyFi XM2GO Battery  ¶
  • Removing the back cover allows access to the user-removable battery.
  • Should the battery need to be replaced or swapped, following these steps will aid in the process.
  • The battery comes from the manufacturer with a pull tab with a web address printed on it to direct the user in purchasing a new battery.
  • Holding the device, grab the tab with thumb and index figure.
Add Note Edit Step 5  ¶
  • Pull down on the tab so that the battery block moves a few millimeters towards the bottom of the device.
  • The battery will move parallel to the back of the device while a latch at the top is freed with the downward motion.
  • There is a pivot point at the bottom of the battery where the contacts connect to the battery.
  • After the latch at the top is disengaged, pivot the battery away from the back and the battery will be free.
Image #1
Add Note Edit Step 6  ¶
  • With the battery removed, the back of the device reveals more information about the product.
Add Note Edit Step 7 — Removing Delphi MyFi XM2GO Logic Board  ¶
  • To start the takedown process, locate the four hex screws on the bottom of the device.
  • Use a T6 hex bit, perhaps from the iFixit precision screwdriver set, to remove the four screws.
Add Note Edit Step 8  ¶
  • To remove the next two T6 screws, locate the button at the top of the back of the device.
  • Around the button, there is a cover that protects the two screws. This cover is accessible by inserting a thumbnail into the bottom and pulling up.
Next » « Previous
Popular Products
Universal Drive Adaptor
$29.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
Anti-Static Mat
iSesamo Opening Tool
$9.95 · 50+ In stock
