Removing the HP Elitebook 6930p RTC (CMOS) Battery
Member-Contributed Guide
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
This guide will show you how to locate and remove the RTC (CMOS) battery from the laptop
  • Author: Richdave
  • Time required: 25 Minutes
  • Difficulty: Moderate
Image #1
Edit Step 1 Battery Removal  ¶
  • Flip laptop over and locate the battery release button
  • Push release button to the left to release battery and gently pull battery from the laptop
Image #1
Edit Step 2 Keyboard  ¶
  • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
  • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
  • Slide the retention clips toward the keyboard to release the keyboard
Image #1
Edit Step 3  ¶
  • Use a plastic pry tool to lift the rear edge of the keyboard.
  • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
  • Lift the keyboard up to reveal the ribbon connectors
Image #1
Edit Step 4  ¶
  • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
  • Release the smaller ribbon cable by lifting up the white retainer
  • I found it easier to reinstall both cables with the new keyboard resting on the back edge
Image #1
Edit Step 5 RTC (CMOS) Battery  ¶
  • Locate the the battery
  • If the battery wires are running underneath the WLAN module you will have to remove it first. In my case it was necessary to remove the WLAN module.
  • Disconnect the battery from the connector
  • Removing the battery and leaving it disconnected more than 5 minutes causes all passwords and CMOS settings to be cleared.
  • Gently un-clip the battery from the plastic housing to completely remove it from the laptop
For more information, check out the HP Elitebook 6930p device page.
Required Tools
Phillips #1 Screwdriver
$5.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
iFixit Lock Pick Set
Inspection Scope
$39.95 · 50+ In stock
Frictionless Ratchet
$24.95 · 50+ In stock
Portable Anti-Static Mat
$34.95 · 43 In stock
Popular Products
Unibody Laptop Dual Drive
PC3-8500 4 GB RAM Chip
$54.95 · 22 In stock
Small Suction Cup
SIM Card Eject Tool
Comments Comments are onturn off
No comments.
Today: 2
This Week: 69
This Month: 230
All Time: 2,757
