Removing iMac G4 15" 700 MHz EMC 1873 Outer Base Plate
  1. Removing iMac G4 15" 700 MHz EMC 1873 Outer Base Plate, Outer Base Plate: step 1, image 1 of 2 Removing iMac G4 15" 700 MHz EMC 1873 Outer Base Plate, Outer Base Plate: step 1, image 2 of 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Removing iMac G4 15" 700 MHz EMC 1873 Outer Base Plate: step 2, image 1 of 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
7 other people completed this guide.
Elliot Freerks
896 Reputation
3 Guides authored
Cal Poly, Team 5-32, Amido Fall 2011 Member of Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 24
All Time: 3,952
