Remove the Screen
  1. Remove the Screen, Remove Screws: step 1, image 1 of 3 Remove the Screen, Remove Screws: step 1, image 2 of 3 Remove the Screen, Remove Screws: step 1, image 3 of 3
    • Remove the screws from the bottom, right, and left side of camera.
  2. Remove the Screen, Remove back: step 2, image 1 of 1
    • Remove the back of the camera, this may require force.
  3. Remove the Screen, Remove Metal Bracket: step 3, image 1 of 1
    • Unscrew the right metal bracket of the viewing lens
  4. Remove the Screen, Remove front of camera: step 4, image 1 of 1
    • Unscrew the top right corner screw
  5. Remove the Screen: step 5, image 1 of 1
    • Unscrew the bottom right corner screw.
  6. Remove the Screen: step 6, image 1 of 2 Remove the Screen: step 6, image 2 of 2
    • Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force.
  7. Remove the Screen: step 7, image 1 of 2 Remove the Screen: step 7, image 2 of 2
    • Pull the front of the camera off of the mother board.
  8. Remove the Screen, Remove the Screen: step 8, image 1 of 1
    • Unhinge the outer case of the screen from the back of the camera. The screen should still be hanging by wires.
  9. Remove the Screen: step 9, image 1 of 1
    • Remove outer case/rim of screen from the back of the camera. The screen should still be hanging by the red wire and white wire.
  10. Remove the Screen: step 10, image 1 of 1
    • Pull out the red wire and white wire attaching the screen to the motherboard.
  11. Remove the Screen: step 11, image 1 of 1
    • Flip up black lever holding data cable to motherboard, and remove data cable from motherboard.
Melissa
240 Reputation
2 Guides authored
Ohio State, Team 1-2, Buehl Spring 2013 Member of Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 386
