Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix
  1. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix, Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 1, image 1 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix, Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 1, image 2 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix, Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 1, image 3 of 3
    • Remove the single screw using a Phillips #000 screwdriver.
    • Peel back the sticker on the mouse to reveal the two screws behind it.
    • Remove the two screws using a Phillips #000 screwdriver.
  2. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 2, image 1 of 2 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 2, image 2 of 2
    • Use an iFixit opening tool to pry open your mouse.
    • Detach the ribbon cable by squeezing the two grey latches and pulling it out gently.
  3. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 3, image 1 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 3, image 2 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 3, image 3 of 3
    • Use your hands to lift the battery out of the mouse.
    • The battery's wire is still attached to the mouse, so use caution.
    • Use your fingers to detach the cable from the mouse.
  4. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 4, image 1 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 4, image 2 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 4, image 3 of 3
    • Unscrew the five 1.4 mm screws using the Phillips #000 screwdriver.
    • Detach the wire that is connected to the scroll wheel.
    • Be gentle when pulling on the wire, or it could tear.
  5. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 5, image 1 of 2 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 5, image 2 of 2
    • Dip a cotton swab in hydrogen peroxide.
    • Clean the scroll wheel by dabbing the cotton swab around it.
    • Do not put too much hydrogen peroxide on the cotton swab or else the scroll wheel could get damaged.
  6. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 6, image 1 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 6, image 2 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 6, image 3 of 3
    • Reinsert the wire back into its socket.
    • Insert and tighten the five 1.4 mm screws with the Phillips #000 screwdriver.
  7. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 7, image 1 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 7, image 2 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 7, image 3 of 3
    • Connect the battery wire back into the latch.
    • Put the battery back into the battery holder.
  8. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 8, image 1 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 8, image 2 of 3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: step 8, image 3 of 3
    • Connect the wire back into the latch.
    • Screw back the three screws using a Phillips #000 screwdriver.
    • Replace the sticker that was covering the top two screws.
Finish Line
4 other people completed this guide.
Kevin Velez
238 Reputation
1 Guide authored
2 Comments
Listen screw driver is incorrect. Poor disassembly instructions that can easily lead to further irreparable damage to the mouse. Incredibly disappointing
Benjamin Parker - Reply
Cry me a river! If the screwdriver is incorrect i.e., doesn't fit into the screw correctly, don't attempt to make it work but instead try a different sized screwdriver. Wow! What a concept! Quit with the dramatics and just be glad that Kevin took the time to make this guide.
Michael Kolman -
Past 24 Hours: 8
Past 7 Days: 41
Past 30 Days: 223
All Time: 10,931
