Razer Blade 15" (2020) Speakers Replacement
  1. Razer Blade 15" (2020) Speakers Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Razer Blade 15" (2020) Speakers Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Speakers Replacement, Unfasten the back cover: step 2, image 1 of 1
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Speakers Replacement, Loosen the back cover: step 3, image 1 of 3 Razer Blade 15" (2020) Speakers Replacement, Loosen the back cover: step 3, image 2 of 3 Razer Blade 15" (2020) Speakers Replacement, Loosen the back cover: step 3, image 3 of 3
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Speakers Replacement, Remove the back cover: step 4, image 1 of 3 Razer Blade 15" (2020) Speakers Replacement, Remove the back cover: step 4, image 2 of 3 Razer Blade 15" (2020) Speakers Replacement, Remove the back cover: step 4, image 3 of 3
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Speakers Replacement, Soften the battery cable tape adhesive: step 5, image 1 of 2 Razer Blade 15" (2020) Speakers Replacement, Soften the battery cable tape adhesive: step 5, image 2 of 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Speakers Replacement, Remove the battery cable tape: step 6, image 1 of 3 Razer Blade 15" (2020) Speakers Replacement, Remove the battery cable tape: step 6, image 2 of 3 Razer Blade 15" (2020) Speakers Replacement, Remove the battery cable tape: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Speakers Replacement, Disconnect the battery: step 7, image 1 of 2 Razer Blade 15" (2020) Speakers Replacement, Disconnect the battery: step 7, image 2 of 2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Speakers Replacement, Disconnect the right speaker: step 8, image 1 of 3 Razer Blade 15" (2020) Speakers Replacement, Disconnect the right speaker: step 8, image 2 of 3 Razer Blade 15" (2020) Speakers Replacement, Disconnect the right speaker: step 8, image 3 of 3
    • Use the point of your spudger to press on alternating sides of the right speaker (labeled R) connector to "walk" it out of its socket.
  9. Razer Blade 15" (2020) Speakers Replacement, Unfasten the right speaker: step 9, image 1 of 2 Razer Blade 15" (2020) Speakers Replacement, Unfasten the right speaker: step 9, image 2 of 2
    • Use a Phillips screwdriver to remove the two 7.6 mm screws securing the right speaker.
  10. Razer Blade 15" (2020) Speakers Replacement, Remove the right speaker: step 10, image 1 of 2 Razer Blade 15" (2020) Speakers Replacement, Remove the right speaker: step 10, image 2 of 2
    • Remove the right speaker
  11. Razer Blade 15" (2020) Speakers Replacement, Disconnect the left speaker: step 11, image 1 of 3 Razer Blade 15" (2020) Speakers Replacement, Disconnect the left speaker: step 11, image 2 of 3 Razer Blade 15" (2020) Speakers Replacement, Disconnect the left speaker: step 11, image 3 of 3
    • Use the point of your spudger to press on alternating sides of the left speaker (labeled L) connector to "walk" it out of its socket.
    • If the cable is tightly wedged under the Wi-Fi card, use your Phillips screwdriver to slightly loosen the screw securing it, freeing the speaker cable.
  12. Razer Blade 15" (2020) Speakers Replacement, Unfasten the left speaker: step 12, image 1 of 2 Razer Blade 15" (2020) Speakers Replacement, Unfasten the left speaker: step 12, image 2 of 2
    • Use your Phillips screwdriver to remove the two 7.6 mm screws securing the left speaker.
  13. Razer Blade 15" (2020) Speakers Replacement, Remove the left speaker: step 13, image 1 of 2 Razer Blade 15" (2020) Speakers Replacement, Remove the left speaker: step 13, image 2 of 2
    • Remove the left speaker.
  14. Razer Blade 15" (2020) Speakers Replacement, Reassembly information: step 14, image 1 of 2 Razer Blade 15" (2020) Speakers Replacement, Reassembly information: step 14, image 2 of 2
    • During reassembly, make sure the rubber grommets are in place at each screw cutout. You might need to transfer them to your new speakers.
Clay Eickemeyer
68,032 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 25
All Time: 185
