Razer Blade 15" (2020) Charging Port Replacement
  1. Razer Blade 15" (2020) Charging Port Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Razer Blade 15" (2020) Charging Port Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Charging Port Replacement, Unfasten the back cover: step 2, image 1 of 1
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Charging Port Replacement, Loosen the back cover: step 3, image 1 of 3 Razer Blade 15" (2020) Charging Port Replacement, Loosen the back cover: step 3, image 2 of 3 Razer Blade 15" (2020) Charging Port Replacement, Loosen the back cover: step 3, image 3 of 3
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Charging Port Replacement, Remove the back cover: step 4, image 1 of 3 Razer Blade 15" (2020) Charging Port Replacement, Remove the back cover: step 4, image 2 of 3 Razer Blade 15" (2020) Charging Port Replacement, Remove the back cover: step 4, image 3 of 3
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Charging Port Replacement, Soften the battery cable tape adhesive: step 5, image 1 of 2 Razer Blade 15" (2020) Charging Port Replacement, Soften the battery cable tape adhesive: step 5, image 2 of 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Charging Port Replacement, Remove the battery cable tape: step 6, image 1 of 3 Razer Blade 15" (2020) Charging Port Replacement, Remove the battery cable tape: step 6, image 2 of 3 Razer Blade 15" (2020) Charging Port Replacement, Remove the battery cable tape: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Charging Port Replacement, Disconnect the battery: step 7, image 1 of 2 Razer Blade 15" (2020) Charging Port Replacement, Disconnect the battery: step 7, image 2 of 2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Charging Port Replacement, Label the antenna cables: step 8, image 1 of 2 Razer Blade 15" (2020) Charging Port Replacement, Label the antenna cables: step 8, image 2 of 2
    • In the next two steps, you'll disconnect the Wi-Fi antenna cables to access other components.
    • The antenna cables look very similar. Label one of them with a piece of tape or marker and remember which socket it connects to.
  9. Razer Blade 15" (2020) Charging Port Replacement, Disconnect the antenna cables: step 9, image 1 of 3 Razer Blade 15" (2020) Charging Port Replacement, Disconnect the antenna cables: step 9, image 2 of 3 Razer Blade 15" (2020) Charging Port Replacement, Disconnect the antenna cables: step 9, image 3 of 3
    $3.99
    Buy
    • Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
    • During reassembly, align the connector over its socket and gently press down with the flat end of your spudger or your fingernail until it clicks into place.
  10. Razer Blade 15" (2020) Charging Port Replacement, Disconnect the screen press connector: step 10, image 1 of 2 Razer Blade 15" (2020) Charging Port Replacement, Disconnect the screen press connector: step 10, image 2 of 2
    • Grab the pull tab on the screen connector.
    • Pull up to disconnect the connector from its socket.
    • During reassembly, align the connector over its socket and press down until it clicks into place.
  11. Razer Blade 15" (2020) Charging Port Replacement, Disconnect the charging port: step 11, image 1 of 3 Razer Blade 15" (2020) Charging Port Replacement, Disconnect the charging port: step 11, image 2 of 3 Razer Blade 15" (2020) Charging Port Replacement, Disconnect the charging port: step 11, image 3 of 3
    • Use the point of your spudger to press on alternating sides of the charging port connector to "walk" it out of its socket.
  12. Razer Blade 15" (2020) Charging Port Replacement, Move the charging cable: step 12, image 1 of 2 Razer Blade 15" (2020) Charging Port Replacement, Move the charging cable: step 12, image 2 of 2
    • Move the charging cable over the right edge of the laptop.
  13. Razer Blade 15" (2020) Charging Port Replacement, Unfasten the right hinge cover: step 13, image 1 of 1
    • Use a Phillips screwdriver to remove the three 6.7 mm screws securing the right hinge cover.
  14. Razer Blade 15" (2020) Charging Port Replacement, Remove the right hinge cover: step 14, image 1 of 2 Razer Blade 15" (2020) Charging Port Replacement, Remove the right hinge cover: step 14, image 2 of 2
    • Remove the right hinge cover.
  15. Razer Blade 15" (2020) Charging Port Replacement, Pry up the charging port: step 15, image 1 of 2 Razer Blade 15" (2020) Charging Port Replacement, Pry up the charging port: step 15, image 2 of 2
    • Hold the charging port cables out of the way of the heatsink.
    • Use the flat end of your spudger to pry up the top screw mount of the charging port until it clears the hinge.
  16. Razer Blade 15" (2020) Charging Port Replacement, Remove the charging port: step 16, image 1 of 2 Razer Blade 15" (2020) Charging Port Replacement, Remove the charging port: step 16, image 2 of 2
    • Rotate the charging port counterclockwise and slide the lower screw mount out from underneath the motherboard.
    • Remove the charging port.
  17. Razer Blade 15" (2020) Charging Port Replacement, The charging port is all that remains: step 17, image 1 of 1
    • You're now left with the charging port and its cable.
Clay Eickemeyer
68,358 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,628 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 40
All Time: 528
