Razer Blade 15" (2020) Back Cover Replacement
  1. Razer Blade 15" (2020) Back Cover Replacement, Unfasten the back cover: step 1, image 1 of 1
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  2. Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: step 2, image 1 of 3 Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: step 2, image 2 of 3 Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: step 2, image 3 of 3
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  3. Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: step 3, image 1 of 3 Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: step 3, image 2 of 3 Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: step 3, image 3 of 3
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
Clay Eickemeyer
68,358 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,628 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 30
All Time: 263
