RCA Maven Pro 11 Volume Button Replacement
  1. RCA Maven Pro 11 Volume Button Replacement, Cover: step 1, image 1 of 2 RCA Maven Pro 11 Volume Button Replacement, Cover: step 1, image 2 of 2
    • Remove all the 8 mm Phillips head screws on the side and back of the device.
  2. RCA Maven Pro 11 Volume Button Replacement: step 2, image 1 of 2 RCA Maven Pro 11 Volume Button Replacement: step 2, image 2 of 2
    • Pry off the cover by sticking a wedge in between the screen and the cover.
    • Be careful with the plastic because it can easily break.
    • Once the cover is partly removed, use your hands to take off the rest of the cover.
  3. RCA Maven Pro 11 Volume Button Replacement, Volume Button: step 3, image 1 of 2 RCA Maven Pro 11 Volume Button Replacement, Volume Button: step 3, image 2 of 2
    • Locate the volume button on the inside of the cover.
    • Slide a wedge between the cover and the volume button and lightly lift it off.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 127
