RCA Maven Pro 11 Reset Button Replacement
  1. RCA Maven Pro 11 Reset Button Replacement, Cover: step 1, image 1 of 2 RCA Maven Pro 11 Reset Button Replacement, Cover: step 1, image 2 of 2
    • Remove all the 8 mm Phillips head screws on the side and back of the device.
  2. RCA Maven Pro 11 Reset Button Replacement: step 2, image 1 of 2 RCA Maven Pro 11 Reset Button Replacement: step 2, image 2 of 2
    • Pry off the cover by sticking a wedge in between the screen and the cover.
    • Be careful with the plastic because it can easily break.
    • Once the cover is partly removed, use your hands to take off the rest of the cover.
  3. RCA Maven Pro 11 Reset Button Replacement, Reset Button: step 3, image 1 of 1
    • Locate the power button on the cover.
  4. RCA Maven Pro 11 Reset Button Replacement: step 4, image 1 of 2 RCA Maven Pro 11 Reset Button Replacement: step 4, image 2 of 2
    • Carefully pull up on the power button. There are two pins holding it in.
    • Remove the power button.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 320
