RCA Lyra X2400 DC Power Adaptor Replacement
  1. RCA Lyra X2400 DC Power Adaptor Replacement, Battery: step 1, image 1 of 3 RCA Lyra X2400 DC Power Adaptor Replacement, Battery: step 1, image 2 of 3 RCA Lyra X2400 DC Power Adaptor Replacement, Battery: step 1, image 3 of 3
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 DC Power Adaptor Replacement, Screen: step 2, image 1 of 2 RCA Lyra X2400 DC Power Adaptor Replacement, Screen: step 2, image 2 of 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 DC Power Adaptor Replacement: step 3, image 1 of 2 RCA Lyra X2400 DC Power Adaptor Replacement: step 3, image 2 of 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 DC Power Adaptor Replacement: step 4, image 1 of 3 RCA Lyra X2400 DC Power Adaptor Replacement: step 4, image 2 of 3 RCA Lyra X2400 DC Power Adaptor Replacement: step 4, image 3 of 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 DC Power Adaptor Replacement, Motherboard: step 5, image 1 of 2 RCA Lyra X2400 DC Power Adaptor Replacement, Motherboard: step 5, image 2 of 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. RCA Lyra X2400 DC Power Adaptor Replacement, DC Power Adaptor: step 6, image 1 of 2 RCA Lyra X2400 DC Power Adaptor Replacement, DC Power Adaptor: step 6, image 2 of 2
    • Locate the DC power adaptor component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
    • Start using solder/desolder tools to remove the DC power adaptor.
    • If you need information on soldering, check out this guide.
    • Once removed replace it with the new working DC power adaptor.
    • Use the soldering tools to reattach the component back to the main logic board.
Joseph Goodwin
1 Reputation
5 Guides authored
Cal Poly, Team 17-3, Regan Spring 2013 Member of Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 192
