RCA CC310 Onboard Microphone Replacement
  1. RCA CC310 Onboard Microphone Replacement, Onboard Microphone: step 1, image 1 of 2 RCA CC310 Onboard Microphone Replacement, Onboard Microphone: step 1, image 2 of 2
    • Lift the metal flap and slide the viewfinder off to the right.
  2. RCA CC310 Onboard Microphone Replacement: step 2, image 1 of 3 RCA CC310 Onboard Microphone Replacement: step 2, image 2 of 3 RCA CC310 Onboard Microphone Replacement: step 2, image 3 of 3
    • Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable is connected to the viewfinder.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Onboard Microphone Replacement: step 3, image 1 of 2 RCA CC310 Onboard Microphone Replacement: step 3, image 2 of 2
    • Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up.
  4. RCA CC310 Onboard Microphone Replacement: step 4, image 1 of 2 RCA CC310 Onboard Microphone Replacement: step 4, image 2 of 2
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  5. RCA CC310 Onboard Microphone Replacement: step 5, image 1 of 1
    • Turn the microphone circuit board over.
    • Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
  6. RCA CC310 Onboard Microphone Replacement: step 6, image 1 of 1
    • Desolder the metal protective housing using a soldering iron.
    • Desolder the microphone and replace it.
Oliver Adams
629 Reputation
6 Guides authored
Cal Poly, Team 5-20, Amido Winter 2011 Member of Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 929
