QFX IT-437 Motherboard Replacement
  1. QFX IT-437 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Motherboard Replacement: step 2, image 1 of 2 QFX IT-437 Motherboard Replacement: step 2, image 2 of 2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Motherboard Replacement: step 3, image 1 of 1
    • In order to unseat the motherboard, use the Phillips PH00 screw driver bit to remove the three 1.2mm x 3mm screws.
  4. QFX IT-437 Motherboard Replacement: step 4, image 1 of 1
    • Once the motherboard is loose, remove the tape above the SD card slot using an iFixit opening pick.
    • Be careful not to rip or damage the tape or else new tape will have to be used for the new motherboard.
  5. QFX IT-437 Motherboard Replacement: step 5, image 1 of 1
    • Use the spudger to remove the ribbon.
    • Avoid using too much force here or else the ribbon can be ripped.
  6. QFX IT-437 Motherboard Replacement: step 6, image 1 of 1
    • Use the spudger in the top corner of the tablet and lift the camera up.
  7. QFX IT-437 Motherboard Replacement: step 7, image 1 of 1
    • Lift the tape over the wires that are holding them to the tablet insulation.
  8. QFX IT-437 Motherboard Replacement: step 8, image 1 of 1
    • Pull out the motherboard and set it aside.
    • The wires must be soldered back on to the motherboard.
2 other people completed this guide.
Douglas
482 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 237
