QFX IT-437 Battery Replacement
  1. QFX IT-437 Battery Replacement, Battery: step 1, image 1 of 1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Battery Replacement: step 2, image 1 of 2 QFX IT-437 Battery Replacement: step 2, image 2 of 2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Battery Replacement: step 3, image 1 of 1
    • Remove the tape connecting the battery to the motherboard.
    • Save the tape in good condition for the replacement so the wires do not get stuck in the case.
  4. QFX IT-437 Battery Replacement: step 4, image 1 of 1
    • Remove the black tape attaching the wires to the battery.
  5. QFX IT-437 Battery Replacement: step 5, image 1 of 1
    • Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
    • The removed wires will have to be soldered back on to the motherboard.
Douglas
482 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 386
