Protocol Dronium One Landing Gear Replacement
  1. Protocol Dronium One Landing Gear Replacement, Landing Gear: step 1, image 1 of 2 Protocol Dronium One Landing Gear Replacement, Landing Gear: step 1, image 2 of 2
    • Remove the eight 5.2mm screws located on the drone base using a Phillips 00 screwdriver with a thin end.
  2. Protocol Dronium One Landing Gear Replacement: step 2, image 1 of 1
    • Once all of the screws are off, lift off the top of the drone.
  3. Protocol Dronium One Landing Gear Replacement: step 3, image 1 of 2 Protocol Dronium One Landing Gear Replacement: step 3, image 2 of 2
    • Remove the two 5.2mm screws holding the landing gear in place using a Phillips 00 screwdriver and an extension if needed.
  4. Protocol Dronium One Landing Gear Replacement: step 4, image 1 of 1
    • Once the inside screws are removed, carefully pull off the one of the landing gear legs. Repeat this step for the other leg.
Ameth Ramos
537 Reputation
5 Guides authored
USF Tampa, Team S2-G5, Sullivan Spring 2017 Member of USF Tampa, Team S2-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 438
