Presto Stirring Popper 0520002 Base Replacement
  1. Presto Stirring Popper 0520002 Base Replacement, Bottom Cover: step 1, image 1 of 1
    • Detach the cover/serving bowl from the popper.
    • Flip the base of the popper over and remove the four 14 mm Phillips #2 screws attaching the bottom cover to the base.
  2. Presto Stirring Popper 0520002 Base Replacement: step 2, image 1 of 2 Presto Stirring Popper 0520002 Base Replacement: step 2, image 2 of 2
    • Removing the bottom cover exposes the internals of the popper. The base holds together the centrally mounted motor and the wires for the power cord and heating element.
  3. Presto Stirring Popper 0520002 Base Replacement, Motor: step 3, image 1 of 3 Presto Stirring Popper 0520002 Base Replacement, Motor: step 3, image 2 of 3 Presto Stirring Popper 0520002 Base Replacement, Motor: step 3, image 3 of 3
    • Remove the two black wire twist caps, and unwind the different wires.
    • During reassembly, make sure the wires are strongly twisted together (twist clockwise) and the wire caps are firmly attached.
    • Avoid swapping the polarity during reassembly. The neutral (ridged) wire connects to the left motor wire and the white wire to the heater.
    • Remove two more 14 mm Phillips #2 screws attaching the white plastic holding the wall cord to the base.
  4. Presto Stirring Popper 0520002 Base Replacement: step 4, image 1 of 3 Presto Stirring Popper 0520002 Base Replacement: step 4, image 2 of 3 Presto Stirring Popper 0520002 Base Replacement: step 4, image 3 of 3
    • Remove the two 14 mm Phillips #2 screws from the motor.
    • Remove the motor from the popper.
    • A spring located in the shaft may force the motor out when the screws are sufficiently loosened.
  5. Presto Stirring Popper 0520002 Base Replacement, Base: step 5, image 1 of 1
    • Remove the four 50 mm screws attaching the base to the heating pan.
    • Removing these screws takes significant force.
  6. Presto Stirring Popper 0520002 Base Replacement: step 6, image 1 of 1
    • Remove the base from the rest of the device.
Kristen Gismondi
83,116 Reputation
204 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,494 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 107
