Presto 0282202 Disassembly
Featured Document
  1. Presto 0282202 Disassembly, Presto 0282202 Disassembly: step 1, image 1 of 3 Presto 0282202 Disassembly, Presto 0282202 Disassembly: step 1, image 2 of 3 Presto 0282202 Disassembly, Presto 0282202 Disassembly: step 1, image 3 of 3
    • Using the Phillips #2 screwdriver, remove the bottom two 25 mm screws off of the coffee percolator.
    • Lighty remove the bottom of the coffee percolator.
    • The wires will keep the two pieces connected.
  2. Presto 0282202 Disassembly: step 2, image 1 of 3 Presto 0282202 Disassembly: step 2, image 2 of 3 Presto 0282202 Disassembly: step 2, image 3 of 3
    • Using the Phillips #2 screwdriver, remove the center 10.8 mm screw holding in the metal strip.
    • Take off the metal strip.
  3. Presto 0282202 Disassembly: step 3, image 1 of 3 Presto 0282202 Disassembly: step 3, image 2 of 3 Presto 0282202 Disassembly: step 3, image 3 of 3
    • Lightly remove the right (bottom facing) thermal switch from its thermal paste.
    • Be careful as the thermal paste can be quite adhesive.
    • Using your small needle-nose pliers, take off the spade connectors connected to the thermal switch.
    • The easiest way to do this is to hold the thermal switch end with the pliers and tug the spade connector off.
  4. Presto 0282202 Disassembly: step 4, image 1 of 3 Presto 0282202 Disassembly: step 4, image 2 of 3 Presto 0282202 Disassembly: step 4, image 3 of 3
    • Lightly remove the left (side facing) thermal switch from its thermal paste.
  5. Presto 0282202 Disassembly: step 5, image 1 of 3 Presto 0282202 Disassembly: step 5, image 2 of 3 Presto 0282202 Disassembly: step 5, image 3 of 3
    • Remove the two spade connectors connected to the heating element.
    • The easiest way to do this is to hold the heating element end with the pliers and tug the spade connector off.
  6. Presto 0282202 Disassembly: step 6, image 1 of 3 Presto 0282202 Disassembly: step 6, image 2 of 3 Presto 0282202 Disassembly: step 6, image 3 of 3
    • Remove the two spade connectors connected to the power connector.
    • The easiest way to do this is to hold the power connector end with the pliers and tug the spade connector off.
    • The final wire removed contains the small heating wire (the thick braided wire) and the signal light.
3 other people completed this guide.
Attached Documents
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 834
