Page 1 of 1
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Logic Board Replacement
Replace the logic board in your PowerBook G4 Aluminum 17" 1.67 GHz (High-Res).
- Author: Walter Galan
- Difficulty: Difficult
This motherboard includes all ports on the right side except USB.
Sections
- Battery 1 step
- Memory Door 2 steps
- Upper Case 7 steps
- Speakers 21 steps
- Logic Board 13 steps
- Logic Board Replacement 1 step
Files
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 5
The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
Edit
Step 8
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
Edit
Step 37
Disconnect both of the following connectors from the logic board:
Left fan cable.
Inverter cable.
Be sure to pull only parallel to the face of the logic board, as pulling up on the socket will break it off the logic board.
When pulling these connectors away from their sockets, it is helpful to use your fingernails to pull on the ears at each side of the connector.
Edit
Step 41
Disconnect the right fan by pulling its connector away from the socket on the logic board.
When pulling this connector away from its socket, it is helpful to use your fingernails to pull on the ears at each side of the connector.
Edit
Step 43
If necessary, use a spudger to pry up the left edge of the logic board to separate the solidified thermal paste from the heat sink.
If any resistance is felt when prying up on the logic board, we recommend softening the thermal paste by heating the board with a hair dryer before prying further.
Edit
Step 44
Lift the logic board from its left edge and rotate it toward the right side of the lower case.
The logic board on this model has a tendency to get caught on the lower case near the DVI port at the upper right corner. If it catches as you are rotating it, stop to avoid bending and breaking the logic board.
Rotate the logic board until it is nearly vertical, and wiggle it around until it releases from the lower case.
When reinstalling your logic board, be sure to apply thermal paste to the CPU. Our thermal paste guide makes it easy.
Only replace the gray thermal paste on the CPU. The white thermal material on the GPU chips can be reused.
Edit
Step 45
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connectors.
If there is a second RAM chip installed, pop it out in the same manner.
This guide has been completed 2 times.
Page 1 of 1
