Page 1 of 1
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Hard Drive Replacement
- Author: iRobot
- Difficulty: Moderate
You can install hard drives up to 12.5mm thick.
Sections
- Battery 1 step
- Upper Case 9 steps
- Hard Drive 3 steps
- Hard Drive Replacement 3 steps
Files
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 8 ¶
Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit Step 14
Remove the two silver Phillips screws and black rubber bumpers from either side of the hard drive (four sets of screws and bumpers total).
There is a black pad on one end of the hard drive that you should peel off and transfer to your new hard drive.
Lift the plastic shield off of the hard drive.
Edit Step 15 ¶
Disconnect the hard drive cable from the hard drive by applying even pressure on both sides while maintaining a firm grip on the drive itself. You may need to remove a piece of orange tape attaching the ribbon cable to the hard drive.
This is a bit tricky. Try holding the drive against your body while pushing the cable away from you, or rocking the cable gently from side to side while applying even pressure, or both. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
If you are installing a new hard drive, we have an OS X install guide to get you up and running.
This guide has been completed 47 times.
Page 1 of 1
