Image #1
Add Note Edit Step 17  ¶
  • Disconnect the large orange hard drive cable from the logic board, removing tape as necessary.
Image #1
Add Note Edit Step 18  ¶
  • Deroute the red and black speaker cable from under the fold in the hard drive ribbon.
Image #1
Add Note Edit Step 19  ¶
  • Lift the hard drive up from the right side and remove it from the computer.
Image #1
Add Note Edit Step 20 — Hard Drive Replacement  ¶
  • Your hard drive should look approximately like this.
Image #1
Add Note Edit Step 21  ¶
  • Remove the two silver Phillips screws and black rubber bumpers from either side of the hard drive (four sets of screws and bumpers total).
  • Lift the plastic shield off of the hard drive.
Image #1
Add Note Edit Step 22  ¶
  • Disconnect the hard drive cable from the hard drive by applying even pressure on both sides while maintaining a firm grip on the drive itself.
  • This is a bit tricky. Try holding the drive against your body while pushing the cable away from you, or rocking the cable gently from side to side while applying even pressure, or both. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Coin
$2.95 · 20 In stock
1.5mm Hex Screwdriver
$9.95 · 4 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
Popular Device Products
100 GB 9.5mm ATA Hard Drive
$99.95 · 1 In stock
G4/MagSafe AC Adapter End
$4.95 · 46 In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 20 In stock
