PowerBook G4 Aluminum 15" 1-1.5 GHz Hard Drive Replacement
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 111
You can install hard drives up to 12.5mm thick.
first image
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 9 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
first image
Add Note Edit Step 4  ¶
  • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
  • Remove the three 3 mm Phillips screws.
  • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
first image
Add Note Edit Step 5  ¶
  • Turn the computer 90 degrees clockwise so that the hinge faces you.
  • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
first image
Add Note Edit Step 6  ¶
  • Rotate the computer 90 degrees clockwise, so that the ports face you.
first image
Add Note Edit Step 7  ¶
  • Turn the computer over and open the display.
  • Remove the 4.2 mm 1/16" H 1.5 hex screws in either corner, next to the display (a T6 Torx driver will also do the job nicely).
first image
Add Note Edit Step 8  ¶
  • This step covers the hardest part to get inside this computer. Take a deep breath and think happy thoughts.
  • Grasp the back corners of the upper case and pull up, disengaging hidden tabs on the sides. Do not pull the upper case off yet; you still need to free tabs in the front of the case.
  • The seam is beneath the plastic molding on the upper case.
first image
Add Note Edit Step 9  ¶
  • There is one latch that stops you from pulling the upper case right off, located on the left side of the optical drive slit. To free the upper case, you will be pulling a thin metal latch toward you, freeing it from the clasp holding it in place.
  • Pry up the left side of the upper case slightly with your hand and wedge a spudger into the seam between the upper case and lower case.
  • Leave the tool in place applying pressure to the upper case for the next step.
first image
Add Note Edit Step 10  ¶
  • Place enough pressure on the upper case to allow you to slide a tool just within the seam between upper case and lower case as shown in the picture. A dentist's hook, push pin, or similar tool will work.
  • Do not yank the upper case off as soon as you free the clasp. The case is attached to the logic board via two ribbon cables.
  • Delicately slip the tip of your tool behind the silver metal latch and pull it forward while pulling up on the case. This may take some effort.
  • Alternatively, you can free the clasp with a small flathead screwdriver through the CD slot. The clasp is 1-3/16 in (3cm) from the left side of the slot. Use the screwdriver to lift out (or press back) the felt lining; then use the screwdriver to pull the clasp (shiny metal) forward to free it from the catch behind it (dull metal).
first image
Add Note Edit Step 11  ¶
  • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  • Rotate the upper case up and toward the screen, so that the upper case rests against it.
first image
Add Note Edit Step 12  ¶
  • Remove the orange tape securing the trackpad ribbon to the logic board.
  • Disconnect the trackpad ribbon from the logic board.
first image
Add Note Edit Step 13  ¶
  • This is a diagram of the keyboard ribbon clamp connector you will disconnect in the next step.
  • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
  • 2) After disengaging the locking bar, slide the cable out of the connector.
first image
Add Note Edit Step 14  ¶
  • Loosen the keyboard ribbon clamp by pushing the thin black piece toward the screen, using the tips of your fingers.
  • The black piece is very fragile and easily broken. Use care when separating it from the main socket.
  • Slide the grey keyboard ribbon out of the loosened connector.
  • Remove the upper case from the computer.
first image
Add Note Edit Step 15 — Hard Drive  ¶
  • Remove the two 6 mm long silver Phillips screws from the metal bracket to the right of the hard drive, removing tape as necessary.
first image
Add Note Edit Step 16  ¶
  • Use a spudger to lift the metal bracket out of the computer.
first image
Add Note Edit Step 17  ¶
  • Disconnect the large orange hard drive cable from the logic board, removing tape as necessary.
first image
Add Note Edit Step 18  ¶
  • Deroute the red and black speaker cable from under the fold in the hard drive ribbon.
first image
Add Note Edit Step 19  ¶
  • Lift the hard drive up from the right side and remove it from the computer.
first image
Add Note Edit Step 20 — Hard Drive Replacement  ¶
  • Your hard drive should look approximately like this.
first image
Add Note Edit Step 21  ¶
  • Remove the two silver Phillips screws and black rubber bumpers from either side of the hard drive (four sets of screws and bumpers total).
  • Lift the plastic shield off of the hard drive.
first image
Add Note Edit Step 22  ¶
  • Disconnect the hard drive cable from the hard drive by applying even pressure on both sides while maintaining a firm grip on the drive itself.
  • This is a bit tricky. Try holding the drive against your body while pushing the cable away from you, or rocking the cable gently from side to side while applying even pressure, or both. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
For more information, check out the PowerBook G4 Aluminum 15" 1-1.5 GHz device page.
Did you successfully follow this guide?
This guide has been completed 111 times.
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Coin
$2.95 · 11 in stock
1.5mm Hex Screwdriver
$9.95 · 17 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
