PowerBook G4 Aluminum 12" 1-1.5 GHz Hard Drive Replacement
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 164
Sections
Files
first image
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — EMI Finger  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the long black Phillips screw next to the memory card.
  • Remove the small EMI finger beneath the black screw.
Next » « Previous
Required Tools
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Coin
$2.95 · 11 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
