Introduction
Replace your PRAM battery & USB board to preserve date and time after system shutdowns and to fix an unresponsive front USB port.
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
Use your fingernail and the tip of a spudger to raise the ZIF cable lock slightly up off its socket.
5 other people completed this guide.
Attached Documents
2 Comments
How do I open this without a torx screwdriver?
