Poukaran ZRW-TD-SRK2 LED Replacement
  1. Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: step 1, image 1 of 3 Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: step 1, image 2 of 3 Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: step 1, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the 7.5mm screws securing the front of the lamp's outer casing or lid.
  2. Poukaran ZRW-TD-SRK2 LED Replacement: step 2, image 1 of 3 Poukaran ZRW-TD-SRK2 LED Replacement: step 2, image 2 of 3 Poukaran ZRW-TD-SRK2 LED Replacement: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the last two 7.5 mm screws securing the back of the lamp's outer casing or lid.
  3. Poukaran ZRW-TD-SRK2 LED Replacement: step 3, image 1 of 2 Poukaran ZRW-TD-SRK2 LED Replacement: step 3, image 2 of 2
    • Once the lid is off, locate and remove the top plate covering the internal components of the lamp.
  4. Poukaran ZRW-TD-SRK2 LED Replacement: step 4, image 1 of 3 Poukaran ZRW-TD-SRK2 LED Replacement: step 4, image 2 of 3 Poukaran ZRW-TD-SRK2 LED Replacement: step 4, image 3 of 3
    • Use a soldering iron to carefully desolder the wires connecting the faulty LED strips. Ensure you're desoldering the correct connections. Solder the new LED strips in place, connecting the wires securely to the designated points on the lamp's circuit board.
    • Exercise caution when lifting the plate that holds the LEDs, as there is a risk of accidentally pulling out the wires.
To reassemble your device, follow these instructions in reverse order. Ensure each component is securely in place and all connections are properly aligned.
andrez oceguera
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 15
All Time: 61
