Polaroid A10 Motherboard Replacement
  1. Polaroid A10 Motherboard Replacement, Back Cover: step 1, image 1 of 3 Polaroid A10 Motherboard Replacement, Back Cover: step 1, image 2 of 3 Polaroid A10 Motherboard Replacement, Back Cover: step 1, image 3 of 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Motherboard Replacement, Motherboard: step 2, image 1 of 3 Polaroid A10 Motherboard Replacement, Motherboard: step 2, image 2 of 3 Polaroid A10 Motherboard Replacement, Motherboard: step 2, image 3 of 3
    • Take off yellow tapes that are surrounding the motherboard.
    • Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
  3. Polaroid A10 Motherboard Replacement: step 3, image 1 of 3 Polaroid A10 Motherboard Replacement: step 3, image 2 of 3 Polaroid A10 Motherboard Replacement: step 3, image 3 of 3
    • Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
  4. Polaroid A10 Motherboard Replacement: step 4, image 1 of 2 Polaroid A10 Motherboard Replacement: step 4, image 2 of 2
    • Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
    • Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
    • Use the same soldering tool to unsolder the ground wire.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Motherboard Replacement: step 5, image 1 of 3 Polaroid A10 Motherboard Replacement: step 5, image 2 of 3 Polaroid A10 Motherboard Replacement: step 5, image 3 of 3
    • Gently lift the motherboard up and out of the device.
Tracie
119 Reputation
1 Guide authored
UW Tacoma, Team 3-3, Rose Winter 2015 Member of UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 599
