Polar V800 Charging Port Cover Replacement
  1. Polar V800 Charging Port Cover Replacement, Watch Band: step 1, image 1 of 3 Polar V800 Charging Port Cover Replacement, Watch Band: step 1, image 2 of 3 Polar V800 Charging Port Cover Replacement, Watch Band: step 1, image 3 of 3
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Charging Port Cover Replacement: step 2, image 1 of 3 Polar V800 Charging Port Cover Replacement: step 2, image 2 of 3 Polar V800 Charging Port Cover Replacement: step 2, image 3 of 3
    • To remove the watch band, pull each end of the watch band away from the watch frame.
  3. Polar V800 Charging Port Cover Replacement, Charging Port Cover: step 3, image 1 of 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: step 3, image 2 of 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: step 3, image 3 of 3
    • Take off the charging port cover.
Nick B.
387 Reputation
1 Guide authored
Cal Poly, Team S17-G6, Livingston Spring 2018 Member of Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Members
8 Guides authored
One Comment
where does not procure the battery port cover ?
Chenthill P - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 2,942
