Plum Optimax 10 Headphone Jack Replacement
  1. Plum Optimax 10 Headphone Jack  Replacement, Back Cover: step 1, image 1 of 2 Plum Optimax 10 Headphone Jack  Replacement, Back Cover: step 1, image 2 of 2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Headphone Jack  Replacement: step 2, image 1 of 2 Plum Optimax 10 Headphone Jack  Replacement: step 2, image 2 of 2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: step 3, image 1 of 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: step 3, image 2 of 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: step 3, image 3 of 3
    • Disconnect the ribbon cable connecting the headphone jack on the motherboard by lifting up on the black press fit connector with a plastic opening tool.
    • Use a plastic opening tool to pry up the headphone jack from its place in the case.
    • The headphone jack is lightly adhered to the back case.
    • When removing the jack, be gentle with the ribbon wire because it is capable of tearing.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 87
