PlayStation 5 Optical Drive Laser Replacement
  1. PlayStation 5 Optical Drive Laser Replacement, Remove the stand screw: step 1, image 1 of 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Optical Drive Laser Replacement, Remove the vertical stand: step 2, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the vertical stand: step 2, image 2 of 2
    • Lift straight up to remove the stand.
  3. PlayStation 5 Optical Drive Laser Replacement, Store the stand screw: step 3, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Store the stand screw: step 3, image 2 of 2
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Optical Drive Laser Replacement, Cap the screw hole: step 4, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Cap the screw hole: step 4, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Cap the screw hole: step 4, image 3 of 3
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Optical Drive Laser Replacement, Close the cubby: step 5, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Close the cubby: step 5, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Close the cubby: step 5, image 3 of 3
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Optical Drive Laser Replacement, Remove the horizontal stand: step 6, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the horizontal stand: step 6, image 2 of 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Optical Drive Laser Replacement, Remove the right faceplate: step 7, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the right faceplate: step 7, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the right faceplate: step 7, image 3 of 3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. PlayStation 5 Optical Drive Laser Replacement: step 8, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement: step 8, image 2 of 2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. PlayStation 5 Optical Drive Laser Replacement, Pry up the grille: step 9, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Pry up the grille: step 9, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Pry up the grille: step 9, image 3 of 3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. PlayStation 5 Optical Drive Laser Replacement, Remove the grille: step 10, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the grille: step 10, image 2 of 2
    • Lift the grille away from the case to remove it.
  11. PlayStation 5 Optical Drive Laser Replacement, Remove the fan shroud screws: step 11, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. PlayStation 5 Optical Drive Laser Replacement, Remove the fan shroud: step 12, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the fan shroud: step 12, image 2 of 2
    • Lift the fan shroud straight up to remove it.
  13. PlayStation 5 Optical Drive Laser Replacement, Remove the wire cover: step 13, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the wire cover: step 13, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the wire cover: step 13, image 3 of 3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. PlayStation 5 Optical Drive Laser Replacement: step 14, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement: step 14, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement: step 14, image 3 of 3
    • Use your fingers to peel off the wire cover.
  15. PlayStation 5 Optical Drive Laser Replacement, Disconnect the fan: step 15, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Disconnect the fan: step 15, image 2 of 2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. PlayStation 5 Optical Drive Laser Replacement, Remove the fan: step 16, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the fan: step 16, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the fan: step 16, image 3 of 3
    • Lift the fan up and out of the case to remove it.
  17. PlayStation 5 Optical Drive Laser Replacement, Remove the SSD cover: step 17, image 1 of 1
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  18. PlayStation 5 Optical Drive Laser Replacement: step 18, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement: step 18, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement: step 18, image 3 of 3
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  19. PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive wire: step 19, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive wire: step 19, image 2 of 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  20. PlayStation 5 Optical Drive Laser Replacement: step 20, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement: step 20, image 2 of 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  21. PlayStation 5 Optical Drive Laser Replacement, Remove the tamper-evident sticker: step 21, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the tamper-evident sticker: step 21, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the tamper-evident sticker: step 21, image 3 of 3
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  22. PlayStation 5 Optical Drive Laser Replacement, Remove the case screws: step 22, image 1 of 1
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  23. PlayStation 5 Optical Drive Laser Replacement, Remove the case: step 23, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the case: step 23, image 2 of 2
    • Lift the case straight up to remove it.
  24. PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive ribbon cable: step 24, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive ribbon cable: step 24, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive ribbon cable: step 24, image 3 of 3
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  25. PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive: step 25, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive: step 25, image 2 of 2
    • Lift the optical drive away from the device to remove it.
  26. PlayStation 5 Optical Drive Laser Replacement, Remove screws from top cover: step 26, image 1 of 1
    • silver screws: 4x M1.6 X 3.7mm, with 6.5mm head.
    • black screws: 9x M1.6 x 3.8mm.
    • Remove screws with Phillips #1 screwdriver.
  27. PlayStation 5 Optical Drive Laser Replacement, Remove top cover: step 27, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove top cover: step 27, image 2 of 2
    • Lift off the top cover.
  28. PlayStation 5 Optical Drive Laser Replacement, disconnect FFC cables and 2 wire lead: step 28, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, disconnect FFC cables and 2 wire lead: step 28, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, disconnect FFC cables and 2 wire lead: step 28, image 3 of 3
    • Gently pull the medium and narrow FFC flexes and the 2-wire lead from their sockets. Suitable tweezers (bent with points or straight blunt end) can be used to aid removal.
  29. PlayStation 5 Optical Drive Laser Replacement, Remove screws from the PCB.: step 29, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove screws from the PCB.: step 29, image 2 of 2
    • black screws: 2x M1.6 x 3.8mm
  30. PlayStation 5 Optical Drive Laser Replacement, Remove base plate: step 30, image 1 of 1
    • Lift off the PCB and attached assembly from the metal plate.
  31. PlayStation 5 Optical Drive Laser Replacement, Flip over: step 31, image 1 of 1
    • Turn over the PCB and attached assembly.
  32. PlayStation 5 Optical Drive Laser Replacement, Disconnect FFC cable and remove the PCB.: step 32, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Disconnect FFC cable and remove the PCB.: step 32, image 2 of 2
    • Unlatch the wide FFC socket.
    • Gently remove the wide FFC cable from the socket and set aside the PCB.
  33. PlayStation 5 Optical Drive Laser Replacement, flip over the assembly: step 33, image 1 of 1
    • Flip over the assembly.
  34. PlayStation 5 Optical Drive Laser Replacement, Remove the screws from mechanism plate: step 34, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the screws from mechanism plate: step 34, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the screws.
    • black screws: 4x M1.6 x 3.8mm.
  35. PlayStation 5 Optical Drive Laser Replacement, Remove the mechanism plate: step 35, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the mechanism plate: step 35, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the mechanism plate: step 35, image 3 of 3
    • Remove the mechanism plate and set aside.
  36. PlayStation 5 Optical Drive Laser Replacement, Remove the FFC cable from laser deck: step 36, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the FFC cable from laser deck: step 36, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the FFC cable from laser deck: step 36, image 3 of 3
    • Push down on the roller mech and remove the FFC cable from laser deck (near roller mech).
    • Blunt end straight tweezers can be used to aide removal of the FFC flex. To remove the flex from the socket, pull the flex towards the rollers.
  37. PlayStation 5 Optical Drive Laser Replacement, Remove the screws holding the laser deck: step 37, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the screws holding the laser deck: step 37, image 2 of 2
    • Remove the screws using a Phillips #1 screw driver.
    • silver screws: 4x M1.6 X 3.7mm 6.5mm head
  38. PlayStation 5 Optical Drive Laser Replacement, Remove the laser deck: step 38, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the laser deck: step 38, image 2 of 2
    • Remove the laser deck.
  39. PlayStation 5 Optical Drive Laser Replacement, Remove the screws from metal plate over laser motor: step 39, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the screws from metal plate over laser motor: step 39, image 2 of 2
    • Remove the screws from metal plate over laser motor.
    • Use a Phillips PH0 screwdriver to remove the screws.
    • silver screws: 2x M1.7 X 3.8mm
  40. PlayStation 5 Optical Drive Laser Replacement, Remove the metal plate over the laser motor: step 40, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the metal plate over the laser motor: step 40, image 2 of 2
    • Remove the metal plate covering the laser motor.
  41. PlayStation 5 Optical Drive Laser Replacement, Remove the screws holding the laser motor to the drive deck: step 41, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the screws holding the laser motor to the drive deck: step 41, image 2 of 2
    • Remove the screws holding the laser motor to the drive deck.
  42. PlayStation 5 Optical Drive Laser Replacement, Flip over and remove the screw from the white plastic bracket.: step 42, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Flip over and remove the screw from the white plastic bracket.: step 42, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Flip over and remove the screw from the white plastic bracket.: step 42, image 3 of 3
    • flip over and remove a single black screw from white plastic bracket.
    • Note: laser motor will be loose, so be careful when you flip over the deck for the next step.
    • Remove the screw with a Phillips PH0 screwdriver.
    • black screw: 1x M1.4 x 3.9mm
    • Remove the white bracket and set aside.
  43. PlayStation 5 Optical Drive Laser Replacement, Flip over the laser deck and move the laser motor to the side: step 43, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Flip over the laser deck and move the laser motor to the side: step 43, image 2 of 2
    • Flip over the laser deck and move the laser motor to the side
  44. PlayStation 5 Optical Drive Laser Replacement, Remove the rod retention clip.: step 44, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the rod retention clip.: step 44, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Remove the rod retention clip.: step 44, image 3 of 3
    • remove the clip that stops the rod from being removed.
    • a) Use a 1.5mm slotted screwdriver to push the lower end of the clip to the left, to unhook it from the retaining hook.
    • b) The clip should pop up.
    • c) lift out the clip.
  45. PlayStation 5 Optical Drive Laser Replacement, Slide out the rod from the laser module.: step 45, image 1 of 3 PlayStation 5 Optical Drive Laser Replacement, Slide out the rod from the laser module.: step 45, image 2 of 3 PlayStation 5 Optical Drive Laser Replacement, Slide out the rod from the laser module.: step 45, image 3 of 3
    • slide out the rod from the laser module.
  46. PlayStation 5 Optical Drive Laser Replacement, Remove the laser module: step 46, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Remove the laser module: step 46, image 2 of 2
    • Remove the laser module
  47. PlayStation 5 Optical Drive Laser Replacement, Flip over the laser module: step 47, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, Flip over the laser module: step 47, image 2 of 2
    • Flip over the laser module.
  48. PlayStation 5 Optical Drive Laser Replacement, unlatch the FFC connector and remove the FFC flex from the laser.: step 48, image 1 of 2 PlayStation 5 Optical Drive Laser Replacement, unlatch the FFC connector and remove the FFC flex from the laser.: step 48, image 2 of 2
    • unlatch the FFC connector.
    • Remove the FFC flex from the laser.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
5 other people completed this guide.
David Fear
390 Reputation
1 Guide authored
One Comment
Danke für die tolle und ausführliche Anleitung!
Discs werden wieder gelesen *freu*
Jan Bäumler - Reply
Past 24 Hours: 25
Past 7 Days: 177
Past 30 Days: 842
All Time: 9,916
