PlayStation 3 Motherboard Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. PlayStation 3 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 1
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  2. PlayStation 3 Motherboard Assembly Replacement: step 2, image 1 of 2 PlayStation 3 Motherboard Assembly Replacement: step 2, image 2 of 2
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  3. PlayStation 3 Motherboard Assembly Replacement: step 3, image 1 of 1
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
    • One 30 mm Phillips screw
  4. PlayStation 3 Motherboard Assembly Replacement: step 4, image 1 of 1
    • Remove the control board bracket.
  5. PlayStation 3 Motherboard Assembly Replacement: step 5, image 1 of 2 PlayStation 3 Motherboard Assembly Replacement: step 5, image 2 of 2
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  6. PlayStation 3 Motherboard Assembly Replacement: step 6, image 1 of 1
    • Lift the motherboard assembly out of the lower case.
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 14
All Time: 2,211
